This has standard 5v, ground, TX, and RX.
If I open up the USB-Serial cable that comes with a Sabvoton SVMC72150 and change the connector so I can wire it up to the ASI BAC800 TX & RX pins, can I attach it to the ASI BAC800 and get it to work? Or is there more required?
I am using the bacdoor phone app on a controller I have here where everything works - there are some settings I would like to tweak, but can't since every setting reads as 0 after I connect the app to the motor.
I think last year I may have blown out the serial interface when I plugged it into a machine since LCD communication only worked half the time on this particular controller.
I am going to take a guess there is no standard color code inside these wires for anything.
