iperov said:can anyone please tell me, what I need to buy and to do to get electric rear shifter?
-- Title: KiDi2 electronic derailleur control
-- Author: Telemachus, 2013.
-- Adapted-from: Highschoolrobots.com, jallib Yahoo groups supporters, like Matt
-- Compiler: jaledit 6.2
-- For pinout, do google image search for "16F628a pinout"
-- Description:
-- 6 geared electronic servo control
include 16f628a -- target PICmicro
-- This program uses the 4 MHz internal timer
pragma target clock 4_000_000 -- oscillator frequency
-- configuration memory settings (fuses)
pragma target OSC INTOSC_NOCLKOUT -- Internal clock
pragma target WDT disabled -- no watchdog
pragma target LVP disabled -- no Low Voltage Programming
pragma target MCLR internal -- internal makes developing easier, but best external
-- setup all the pins and alias for them
-- servo control pins
alias servo_1 is pin_a2 -- only 1 servo used for now
;alias servo_2 is pin_a3
;alias servo_3 is pin_a1
alias servo_1_direction is pin_a2_direction
;alias servo_2_direction is pin_a2_direction
;alias servo_3_direction is pin_a1_direction
servo_1_direction = output
;servo_2_direction = output
;servo_3_direction = output
--input pins
alias gear_up is pin_a1 -- Button to increase gear
pin_a1_direction = input
alias gear_down is pin_a0 -- Button to decrease gear
pin_a0_direction = input
enable_digital_io() -- turn off analog
include seven_segment -- Include 7 segment lib
portb_direction = all_output
-- Setup the Servo controlling library
;const byte SERVO_AMOUNT = 1 -- set number of servos
;const byte SERVO_RESOLUTION = 10 -- set movement resolution
const byte SERVO_USE_TIMER = 0
-- Adjust the following to control servo throw from center.
const byte SERVO_MIN = 50 -- set min throw of servo
const byte SERVO_MAX = 255 -- set max throw of servo
;const byte SERVO_CLOCK_BITS = 8
include servo_rc_master -- include the servo library
servo_init() -- Turn on the servo movements
var byte servo_value1 = 80 -- Servo Value for Gear 1
var byte servo_value2 = 109 -- Servo Value for Gear 2
var byte servo_value3 = 119 -- Servo Value for Gear 3
var byte servo_value4 = 130 -- Servo Value for Gear 4
var byte servo_value5 = 145 -- Servo Value for Gear 5
var byte servo_value6 = 165 -- Servo Value for Gear 6
var byte gear_value = 4 -- Default gear upon power up
var byte gear_dif
var byte i -- variable for the 7 segment display
forever loop -- begin main program
i = gear_value
portb = seven_from_digit(i) -- display char
if !gear_up then
_usec_delay(1_000) -- slight delay to assure button press
if !gear_up & gear_value < 6 then
gear_value = gear_value+1
gear_dif = 5
_usec_delay(750_000) -- delay in between shifts
elsif !gear_up & gear_value == 6 then
gear_value = 6
gear_dif = 8
end if
end if
if !gear_down then
if !gear_down & gear_value > 1 then
gear_value = gear_value-1
gear_dif = -5
elsif !gear_down & gear_value == 1 then
gear_value = 1
gear_dif = -8
end if
end if
if gear_value==1 then -- when gear is at 1, move to servo value 1
servo_move(servo_value1+gear_dif,1)
; for 1 loop
; led = on
; _usec_delay(250_000)
; led = off
; end loop
; _usec_delay(1_000_000)
elsif gear_value==2 then -- if gear is at 2, move to servo value 2
servo_move(servo_value2+gear_dif,1)
; for 2 loop
; led = on
; led = off
; end loop
elsif gear_value==3 then -- if gear is at 3, move to servo value 3
servo_move(servo_value3+gear_dif,1)
;for 3 loop
; led = on
; led = off
; end loop
elsif gear_value==4 then -- if gear is at 4, move to servo value 4
servo_move(servo_value4+gear_dif,1)
;for 4 loop
; led = on
; led = off
; end loop
elsif gear_value==5 then -- if gear is at 5, move to servo value 5
servo_move(servo_value5+gear_dif,1)
; for 5 loop
; led = on
; led = off
; end loop
elsif gear_value==6 then -- if gear is at 6, move to servo value 6
servo_move(servo_value6+gear_dif,1)
; for 6 loop
; led = on
; led = off
; end loop
end if
end loop -- end of main program
