jdbauman
1 W
Hi All,
I think I want to build a bike with a 408 Front Hub Motor. I would like to use the Dewalt 36V battery packs without opening up the packs (so as not to void the warranty). I would like to combine the packs in a combination of Series and Parallel connections to get approximately 66V and 7Ah.
I know that others are doing this already, however there seems to be a problem of blowing the BMS unless you bypass it when discharging the battery. My question is, is it the increased Voltage or Amperage that causes the problem with the BMS.
If it is the Amperage, would I eliminate the problem by using the 36-72V (20 Amp) controller instead of the 36-72V (35Amp) controller.
Or
Is there another way to control the Voltage and Amperage to keep it within safe limits, so that I wouldn't blow the Battery BMS.
I would appreciate any helpful ideas on how to protect the battery BMS without alteration to the batteries. Thanks Guys!
Jer
Or
Jer
