I'm installing a BSS02 in a Motobecane 29er and find that the bottom bracket is a really tight fit on first attempt to slide the motor through the bottom bracket tube. The motor shaft gets stuck about halfway through the tube, which probably means where the shaft's threading ends. Running my finger around the inside of the BB there is a very small ridge most noticable at the weld joints, which probably never comes into play with most bottom brackets because they taper at the end of the threading.
I tried a quick dremel grinder to see if just knocking off a couple nubs will get the job done, but didn't happen on the first try. The BB seems to be just barely asymmetric in that I have a bit of play wiggling up and down but almost none side to side, which I think implies the tight spot is around the rear chainstay joints, though it could be just a tight fit overall with an extra millimeter tight on that axis - but it does feel like there is a tiny ridge, rather than a problem on the unthreaded width of the BB so hopeful about just cleaning up a little bit rather than a lot of metal. Spinning the BSS02 shaft doesn't seem to change the tightness of fit so I'm guessing that means the issue is in the bottom bracket dimensions, not the motor.
So it's an 'almost' perfect fit that will be really tight (good) if I can get it through. Any advice will be appreciated, I'm going to look for a better cutting/grinding option and try again with a little more persistence.
Charlie
