Flash-FX
As far as the question regarding the BB in the same exact location, probably not. I thought about that too. lowering helps in stability. But after pedaling the "stock" bike around and trying to imagine where a change would be an improvement, I left it alone (same location). With the "fixture", I could always cut the motor bracket off and make a change. The way it turned out though, I'm going to leave it as is an run it. When you cut the frame tubes,(without support) I'm sure that they will flopping around a bit. That will just create more frustration when trying to get it assembled. It's best to have the tubes somewhat stable. The way the chain line offset is with the stock Bafang spider and chainring, It's kinda set up for a fatbike (the chain just clears the tire like it did stock when in 1st gear). I think having a good chain line is the most important thing. The motor is pretty strong in the stock configuration, you want things aligned and secure.Tpesl said:Thanks for the instructions very informative , i’ll be doing the same thing shortly , my question is do you find that it’s absolutely crucial to have the Bottom bracket at exactly the same position as it was before I can’t see that it would make such a big difference if it was slightly forward or backwards or higher or lower as long as it’s lined up.
Also do you think that if you didn’t do all that support around it before cutting it you would never be able to line it up again? I don’t have an access to a welder so I will have to figure something else.
Thank you
Doing this project without a welder?? Hmmm... I'm sure it can be done, not a easy task. If you have a steel frame you'll need to make a adapter(s) so the motor mount can be bolted on. If your frame is aluminum just have someone weld it for you. Also, make a dummy axle spacer to help with keeping the stays where they need to be when doing the "surgery". You can measure the gear cluster (hi-middle-low) and transfer that over to the dummy for test alignments, as the rear wheel will probably not fit when doing this mod.
