scootergrisen
- Joined
- Feb 26, 2018
- Messages
- 154
This is my balancing adventure.
Have been balancing my two 48V25Ah lithium-ion batteries for my electric scooter/e-bike for days now trying to get all the cell series to be the same voltage.
The BMS is using passive balancing.
It discharges the cell series that has the highest voltage in order to bring the voltage down closer to the cell series with the lowest voltage.
The balancing/discharging is quiet slow.
It stops balancering when the cell series reaches 4,00 volt.
It does not appear that charging starts automatically so i had to turn the charger off and on again to start the charging again.
And then when the charging is done it starts all over again.
Seems like that is taking one week to do for one of the batteries.
The batteries are like 3½ years old now.
The BMS has some nice LED's that flashes to show the balancing.
But you can't see them untill you take the battery apart.
So I want to find a way to figure out if the battery is balanced or not from the outside without taking the battery apart.
Seems like charging is cut off at a higher current (earlier) when the battery is not balanced. Then when better balanced it seems the charging current slowly gets lower and lower.
Also it seems that the battery can both charge and discharger (balancing) at the same time.
I have pretty much been thinking that when there is no current between the charger and battery that the battery is completly done. But turns out it can still be doing balancing for hours. Like many hours. And after the balancing i can accept some more charging but have to turn the charger off and on for the charging to start.
I suppose i can let the battery rest for an hour after it stops accepting any more current from the charger and then measure the voltage of the entire battery and maybe i can use that to know if the cells are balanced or not.
So if the BMS stops charging at 4.150 volt and i got 13 cell series then I should be able to measure 53.95 volt. If everything is ideal.
Well that was my biggest balancing adventure.
Pictures of the batteries and charger:
https://scootergrisen.org/forum/viewtopic.php?f=19&t=3612
https://scootergrisen.org/forum/viewtopic.php?f=19&t=3601
