Callmenobody
- Joined
- Jul 2, 2020
- Messages
- 12
Well, this is all new to me so I hope that I don't ask those annoying questions everyone starts with (I have googled).
Sooo, my in-laws electric IKEA bike broke down and their No1 solution it to leave it at my doorstep and ask me to fix it. No matter what it is.
I removed the battery and noticed that the plastic around the positive connector was melted but since the fuses where ok I guessed that this was due to a bad connection generating heat. So I just opened the battery to check the cells and that everything look ok, then I cut the melted plastic away and plugged the battery back in.
All worked like a dream for a few months but after leaving the bike outside a while during this winter it is quite dead.
The indicator on the battery doesn't light up and I get no voltage between the positive rail and ground.
If I open the battery up and measure the cells they seem to be alright and if I plug the charger directly to the bikes control box (or whatever it is called) the bike lights up.
So I guess that the PCB in the battery is fried.
Now to the question (I like to explain the story behind the problem).
Can I just order a aftermarket 36V xxA battery of a Chinese site and plug it in and get the bike working again? The original battery only has a positive and a negative going to the box so I can't see why not.
As long as the cells fits in the original plastic box that is.
