bobbill
Bob, thanks. Switched charge and discharge connectors to XTs a 60 for charge and 90 for discharge or motor...
Yes, unscrewed connectors...figuring universal use,,,and like you said, 2-wire, so all is fine, as long as i do not short when doing connector change...
Will use the chargers I have and set to 100 (one is 2amp other is larger and is from "that place.") I like, as it has the lights, cooling fan and charge level adjustment.
Saved your instructions and will apply.
Should have done this long ago...cost was about the same but beats all the bullroar endured.
My only complaint, so far, with the supplier is that their Andersons simply do not connect...
Also, have to wrap in foam...nice wee battery, in any case, I must say.
Thanks. Hive
Thanks. Hive
