HI
I have studed forum for a several days and have few question.
I want to build 74V LiPo battery 20s2p
Please advice about my shoping list.
I will use this LiPo 8 pieces but first I will buy only 4.
Are they good? Or better to go with turnigy?
http://www.hobbyking.com/hobbyking/store/__16227__ZIPPY_Flightmax_8000mAh_5S1P_30C.html
To protect before deep discharge I will buy 8 of this for each battery
http://dx.com/p/2-in-1-1-8s-lipo-battery-low-voltage-buzzer-alarm-for-rc-helicopter-white-black-180468
It should make noise when battery drop to critical level during ride, am I right?
I need charger, found two:
http://www.hobbyking.com/hobbyking/store/__6609__iCharger_1010Bplus_300W_10s_Balance_Charger.html
or
http://www.hobbyking.com/hobbyking/store/__9005__iCharger_208B_350W_8s_Balance_Charger.html
Which one will be better for parrel charging 8 bateries?
I need power supply for this charger, I do not know which to pick, please help me to choose.
I want parallel charging so I need parallel charging board, I do not found any board on HK for 8 packs 5s, maybe better do like on the picture?
![](/sphere/proxy.php?image=http%3A%2F%2Fi23.photobucket.com%2Falbums%2Fb365%2FMixhaL7%2FForum%2Fth_315567_10150289617206073_715006072_8050723_1871738872_n28Custom29_zpsfe9ef144.jpg&hash=b52315f897d9d625c02f13d36e1f6c1a)
So I will buy JST-XH Parallel Balance Lead 5S
http://www.hobbyking.com/hobbyking/store/__27074__JST_XH_Parallel_Balance_Lead_5S_250mm_6xJST_XH_.html
And make the same with power leads
I will buy HXT 4mm connectors and power wire 12 AWG to do power leads
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=9283
http://www.hobbyking.com/hobbyking/store/__9673__Turnigy_Pure_Silicone_Wire_12AWG_1mtr_RED.html
http://www.hobbyking.com/hobbyking/store/__9674__Turnigy_Pure_Silicone_Wire_12AWG_1mtr_BLACK.html
Balance Plug Savers (JST-XH 5s) to better unplug
http://www.hobbyking.com/hobbyking/store/__19942__Balance_Plug_Savers_JST_XH_5s_5pc_Per_Bag_.html
Do I need something more to build a battery pack?
Thank You
or
Thank You
