Direkt1218
Purchased a very well used eDrift scooter from FB marketplace. I think I got a great deal BUT the battery arcs when I connect in to the controller.
Let me back up a little. The gentleman I bought it from did not know anything about it. He said the battery pack was fried. So that is where I started. No voltage at the connector Well it’s already broken let’s dig deeper. Take the shrink off and test right at the BMS terminals. Hey look 63v!!! Pack IS good just the wiring was a total mess. Finished unwrapping it and removing all the messed up wiring. Installed fresh 12GA silicone wire and xt60 connectors. Then cleaned up the wiring on the scooter itself. But when I connect the xt60 connectors together I can hear/ see a pretty good arc. So the male xt goes to a terminal strip so the pack can feed a buck converter (12vdc out) and the controller. SPD-602000BLDC controller. Nothing fancy. Am I missing something between the battery and the controller? A relay? A key switch? This arcing can’t be good or sustainable. It’s going to destroy the xt60 connectors eventually. The motor spins when the battery is connected and the throttle is applied so my rewire seems successful. At least to me it seems successful. Any guidance would be very wonderful. Thanks!
