dannydoyle2
- Joined
- May 31, 2016
- Messages
- 19
My Eboard is currently running on two big fat 8000mAh 5S LiPo packs, which is a bit annoying. Which is why I'm looking for a replacement for them.
I've considered going with 18650 batteries like the LG HE2, but I don't wanna invest in a spot soldering machine that I'm just going to use once. On top of that, I've read that the LG HE2's have a lifecycle of just about 300 recharge cycles, which sucks a bit imo.
So I've been looking around a lot and I just stumbled across these things:
http://www.headway-headquarters.com/40152s-15ah-headway-cell/
(Exact specs are in the second product pic)
Now first of all, they're super long at 150mm/5.9in and quite thick at 40mm/1.6in. However, they're rated at 15,000mAh each which makes them quite attractive, since I won't have to deal with soldering or welding a lot of batteries together. Plus they have screw caps at the and which might eliminate the night to solder altogether.
So essentially I have:
+ I'd only have to use 10 of those to get a 10s pack going
+ 15,000mAh more than enough
+ not that expensive at around 30 bucks each
+ screw caps
+ discharge current of up to 150A
- long and unflexible
. balancing needed, since they're LiFePo4's
I'm really thinking about buying them, but for some reason I can't shake the feeling that I'm overlookin something. Why isn't everyone else using them as well? Is it because of the balancing that's required and the advantage that the 18650's have over them? Anything else I'd need to consider when charging them?
+ screw caps
