technotony007
- Joined
- Nov 23, 2019
- Messages
- 71
Hi,
After going through the usual expensive route of trying source use different types of Fake chinese sourced ah batteries. The ebike i use seems to drain them pretty quickly. It had wrecked two BMS's , to which i had to remove them and then it cooked the both batterys , as they got unsafely hot. I am thinking about building and a large square 52V 50ah with 21700 cells, sized battery for my Vapour ebike. My plan is put this put this in a ruksack or backpack. I have seen another system that that does this also, this is the Paradox Kinetics system.
We queries to start off this Thread is :
1. has anyone else done this before ?
2. what precautions did they take , in case of failures ?
3. what size of batteries did they use ?
I am using the Bafang M620 G510 unit , which has been upgraded with The X1 controller , and has larger 60 A power cables fitted to it.
if anyone out there uses this X1 controller on their bafang unit , please can you let me know which size and type of battery consturction they use also ?
Any help , thoughts , contributions in ideas to this would be greatly Appreciated.
