Votol EM 150/2 SP with a QS138 V3 motor and a 20s8p battery. Everything is perfect I love this set up. I works flawlessly except for 1 thing... It will cut off from time to time. This is a motocross bike.. If the chain is a little too loose...(and going through a whoop section) or the track is very rough..(even with the chain adjustment correct)... it will cut off from time to time.. If the track is rather smooth & we are assuring chain adjustment everything is perfect. I do have the solid gear in the gear reduction so the issue with the gear slipping on the shaft is not an issue .. its almost like the rear wheel is getting confused on where it is with the motor..
