number1cruncher
Recently, there was a group buy for Bestech BMSs coordinated by member Dnmun. The process went really smooth and I thought I would post my set up and initial results. Although the BMS has the capacity for 24 cells, I set it up for 18.
Below is a picture of the D131 24S Lipo BMS I selected:
First, I soldered the main wires using 10awg for B-, P- and 12awg for C-.
Next, I connected the sense wires to 7 pin JST connectors, so I could swap out packs easily. I included both female connectors for the pack balance connections and male connectors for CellLogs.
All direct connections to the BMS are finished, so now I assembled a positive harness including a fuse using 10awg for the P+ and 12awg for the C+.
I then tested the setup outside of the case to ensure easy troubleshooting. No problems.
I picked up a $7 toolbox at Walmart to use as a case. The discharge cable is routed out the side, down through an overhang. The celllog connectors and charge cable is routed out the top, which has a lid to keep the water out.
I have been using the pack for about two weeks now. It balances all 18 cells to within 17mV, from 4.183 to 4.200.
The LVC and HVC functions have not been tested yet. When I have a chance to do this I will post my results.
Thank you Dnmun for taking the time to set up the group buy. This BMS should make my ebikes a lot safer and hopefully extend the pack life.
