lostrack
I just read in Dogati's thread about a V3 Cycle Analyst bursting with new features...for RC.
Where can I find out more about this??
lostrack said:I just read in Dogati's thread about a V3 Cycle Analyst bursting with new features...for RC.
www.recumbents.com said:Can you speed up the feedback loop or dampen the oscillation? Hmm maybe it makes more sense for me just to resolve this by slowing the throttle ramp up speed in the CC HV160 ESC. I'll give that a try.
-Warren.
Kepler said:I have tried all sorts of tuning strategies to try and get around this and have managed to improve things. However, its still not perfect and at this point, due to its intermittent nature feel it may be an issue that needs to be fixed at code level.
Observations:
=> On first startup, the surge never occurs. I believe this is due to the ESC's inbuilt ramp is dampening it out.
=> If you coast at zero throttle for more then 5 seconds, then apply throttle, the surge does not occur. I believe this because the ESC ramp has reset within this timeframe and again is used to dampen the throttle up.
=> Most likely time to see the surge is if you come to a quick stop and then throttle back up again. This when I can see a surge voilent enough to lose motor sync.
=>Throttle up surges if you coast at zero throttle then throttle backup while the bike is still coasting. With my 1500W setup, its not too bad, but should be better.
Kepler said:Thanks Justin.
I should have my programmer in the next few days and look forward to testing the new code.
If anyone wants to have a go at loading the new code, best method is to use a Pickit-3 I got mine off ebay http://www.ebay.com.au/itm/ws/eBayISAPI.dll?ViewItem&item=110563067149
Justin never did a bootloader in the chip? If he did ypou might only need usb-serial adapter to change it. But if you need to change major things then it might be a full reflash.www.recumbents.com said:I hope Justin has a plan for upgrades for us beta testers. Otherwise it's going to be a choice between paying for sending the CA somewhere and paying to have it flashed with the new code revision and then sent back, buying a $40 gizmo to do ourselves, or just living with it.
-Warren.
Arlo1 said:Justin never did a bootloader in the chip? If he did ypou might only need usb-serial adapter to change it. But if you need to change major things then it might be a full reflash.
Awesome! I would offer to reflash anyones CA if they need but Its proly the same price or cheeper (for shipping) and quicker to send them strait to Justin.justin_le said:I wanted to, but quite literally had no room left in memory to fit a bootloader by the time all the V2.2 features were added to the firmware! In the V3 units this was first order of action to implement, so going forwards everything will be upgradeable just with a serial->USB cable.
-Justin
Kepler said:Good news is I have my PICkit-3 and have uploaded the updated firmware into my CA. Looking forward to some serious testing in the morning. 8)
