adamsavage79
I had to replace the Motor wire for my bike, but that didn't work. So the entire Motor was replaced. The bike does work normally for the most part, but I find after reaching about 40 kph, the motor starts throttling the power and it's quite the effort to get it to go past 43 kph on a flat surface. Before, I was able to cruise @ 42-43 with motor near full power. I found a you tube video that shows the full settings in the LCD, but without knowing what the default settings are. I'm not comfortable with tinkering with that.
If I had the default settings, I could compare to what I see now, and perhaps see why the controller or LCD is causing the motor to dial back the power.
Links to the Bike and LCD Video:
Teslica Purity Mountain Ebike M1H
Teslica Purity M1H Mountain Ebike. With 500W Motor and a 48Volt. 15 Month Warranty. <br /> Serving Ottawa, Gatineau, and surrounding region.
www.teslica.com
