rowbiker
I was not able to access your attached photo -- only a placeholder icon is being displayed. Could you re-upload the photo please?
crustulu said:Some updates from my side.
My 48v CanBus system with dead BMS works like a charm. I use it everyday.
For now i just removed the BionX BMS, installed a standard 13s Chinese BMS with balancing function, added 2 DC/DC converter one for +5V and one for +12V. I also added a opto-magnetic 30A relay operated by the +5V and a simple rocker switch on the outside of the battery. When the switch is off, the DC/DC converters are disconnected and the relay is in idle position witch means that the + of the battery is connected to the charge plug. When the switch is on the DC/DC converters are on, the relay is activated and the + of the battery is connected to the socket. Do not plug a battery in the bike with tension on the socket, it will produce a huge spark.
The CanH and CanL wires are shorted with a 240 Ohm resistor for the moment.
The console and the motor can communicate without the battery original BMS, the only things that lacks are the battery gauge, the regeneration and the odometer that acts very strangely. No automatic shut-down after 10 minutes like it was said above.
On the CanBus Hack side, for now i just listened to the communications of the system on my wife's bike witch is fully functional. I think that i have discovered the codes for battery voltage, state of charge, regen on/off. The problem is that the Arduino doesn't fit inside the battery rigth now, i have to reprocesses the overall wiring for that. I will continue that later i think.
Cheers,
Alexandre.
wdeutsch said:For anyone who trips across this dead thread in the future, I repeated what Auber38 (June 16, 2020) did up above. It worked perfectly! I have function back, except no regen braking and no battery monitor. The controller seems a bit slower to respond than it did before, but I have a functioning system again!
Is it wired directly to the battery?iacei said:Fun Fact, the lights do not work or is there a light sensor that holds the lights from shining even if turned on?
