Skippic
My intention is to make an Arduino driven BMS. This is for a 24s LiPo pack. The idea is to use a multiplexer to turn on a solid state relay at each cell connected in series with a resistor and an analog optocoupler (in parallel).
It should work by checking the voltages once every minute (while charging or in use), if it detects a cell below 3.6V it sends LVC signal.
If the pack is charging and the max voltage is more then 4V and a cell is 0.1V above the lowest cell it discharges the highest cell for one minute.
I need help selecting the most suitable components. At the moment the best solid state relay I found is the LH1547 at about $0.90 a piece shipping included. It's max current rating is 120mA (a little low). But since it will be balancing every charge and I will use a charger of my own making, so the BMS can turn it on and off as many times as I like to get the pack balanced and fully charged it should be OK.
My biggest problem is searching for analog optocouplers. I've been able to find the HCNR201 at $3.10 each. That's $74.40 for optocouplers! Is there a cheaper analog optocoupler? It doesn't need to be perfectly linear, just give consistent output values at the same input for all the cells.
Just to avoid multiple posts: yes I'm using the same circuit for measuring and discharging the cells. The difference is, that for measuring all that is needed is a few ms, while for discharging it's in order of minutes or hours.
I'm also thinking of placing a small capacitor in series with the optocoupler, so it doesn't burn the LED when discharging.
Originally the idea was to use a separate MUX for reading the opto values, but maybe I can use them connected with common output or at least through resistors with reduced sensitivity. Can someone tell me what is the best solution here?
