knurn
I built an ebike years ago from a Grubee kit with lead acid batteries. I am now returning to the EV scene with a newer bike and a direct drive 1000 watt Golden Motor that I have had sitting around idle. Choices today are overwhelming - which is actually a good thing
I am starting to look into purchasing a battery pack (lifepo4, 48 V 15 AH). The pack will include a BMS.
I have seen options for the discharge rate as listed below:
20 - 40A (20 continuous discharge current, 40A peak discharge)
30 - 60A
50 - 100A
I understand the motor controller delivers and regulates power to the motor and the BMS protects the battery from operating outside its safe operating area. Is it better to purchase a battery pack with a higher discharge rate or is it necessary to have a match between the BMS, batteries and the controller? I have a direct drive 1000 watt Golden Motor.
Thanks in advance.
30 - 60A
50 - 100A
Thanks in advance.
