The whole discussion of "ABS" is a crock... ALL car ESCs use the current generated by the motor spinning to generate backpressure or competing field - effectively the same as when you short the connections on your motor and spin it. This works in an ABS fashion because the current generated is proportional to RPM and the braking force is equivalent to that current so as the motor slows the braking force falls off ... when no spinning occurs no current generates and no braking occurs ... its just like ABS in cars but not really as it is just normal electric motor system behaviour. So all ESCs have "ABS" but it's not really ABS ... it's just the way it works.
Compared to an HK150A (the only ones I've used so far in my builds as Hobbywings are about 50% more expensive in Australia) the acceleration on the Alien, especially from very low speeds seems to be superior ... just a little better and smoother now I'm on new firmware. The braking on the HK150A though is smooth and buttery ... quite a joy, quite predictable and with lots of oomph if you turn it right up... the Alien is like riding over a bed of really rough stone while braking. I'm not sure if it is this fact or something else in the design but so far I've also lost 8 bolts due to vibrating loose on long rides in spite of using loctite. I'm upgrading to loctite blue to see if that is better.
On mods, I've turned down the inside flange of the motor pinion to allow it to clear all the motor mount screws. This makes for a much smoother experience as I need to get the pulleys right in to remove belt rub. This has made the ride much smoother.
A question, for those with the Holey mount system how much riser are you running? I am up to 1/2" risers now and I still get board rub on the motors in a turn.
If I were to recommend points for a redesign of the Holey bracket I would say:
- The motors need to be tilted away from the board a lot more ... at least 15 degrees, and maybe as much as 25.
- The bracket should be slotted and the motor plate tapped (instead of currently the other way around) to allow adjustment of belt tension without removing the wheel.
- The belt length need to be shorter ... even with the lame braking I am getting belt skip on belt I have already set to tight (to see if I could stop the skip).
- The bolt guide that locates the bolt which secures the mount to the truck seems to strain the bolt in so many ways it defeats even loctite. I got rid of this by using a cylindrical spacer to stand the bolt snug inside the Holey truck hole (two different sizes required) and just a washer then sprung washer. I have two of these now and they haven't come loose even without locktite (I cleaned out the thread so it bolts and unbolts freely).
- I have some old alien wheel pulleys with an inner flange on them to keep the belt from rubbing on the wheel. In the last few days I've already exposed the metal in a new belt with the newer pulley which doesn't allow this. Now there is not a lot a room here because of the size of the Holey truck so I've used a stick on teflon coated ring on the back of the wheel. It works really well at reducing wear and belt binding. Probably any slippery shim would do though and would be trapped by the belt.
