gogreenpower
Hi guys,
It’s been a few years since my last build but I’m back and jumping straight into the deep end.
I'm building a BBSHD Full Suspension fatty, it has a 120mm BB with room to add a couple of 4.7" Vee Tire Bulldozers, then later on down the track I'm adding a Rohloff XXL 500/14 and if possible a Gates belt drive. It will be used nearly exclusively on the beach.
Here is the bike:
I've broken it down into 4 stages.
Stage 1:
First thing is fitting the BBSHD kit and battery. The chainline looks good and I don’t foresee any problems with fitting the BBSHD. Unfortunately it requires a custom made battery to fit what I want in the frame. I thought about backpack batteries but that’s not for me.
I want to have around 15Ah or more, it depends on what I can fit in the triangle, I have 11 different bags on the way so I will have a better idea when they arrive... I want to have another removable 10Ah split into two packs in a bag over the top tube.
I plan on using Sanyo NCR18650GA in a 14s5p with BMS for the triangle and for the removable top tube bag split into 2 packs of 6s3p and 8s3p to accommodate a BMS on one side.
I am using the Bestechpower HCX-D167's. 35A max continuous.
http://bestechpower.com/518v14spcmbmspcbforli-ionli-polymerbatterypack/PCB-D167.html
Now if I understand my battery theory correctly which is highly debatable, i have come up with this.
Given that the BBSHD controller can draw 30A continuous, unsure on the surge?, and the GAs are rated at 10A, 5p will give me 50A continuous limited to 35A through the BMS to feed the 30A controller.
Stage 2:
I plan on fitting a couple of 4.7" Vee Tire Bulldozers on the front and rear 100mm rims and going tubeless. The gap on the forks is 4.8" so I assume that's enough clearance? If anyone has run this sort of gap before, how did it go? I really need as much tyre as I can get for the sand. And if anyone has any ideas about a better soft sand tyre please let me know.
http://www.veetireco.com.au/#!product/prd12/1764633255/bulldozer---26%22-x-4.7%22
Stage 3:
My original plan involved fitting a Nuvinci N380, but with 190mm dropouts that won't work so I have found a Rohloff XXL 500/14 designed for my exact size.
https://www.rohloff.de/en/products/speedhub-xxl-fatbike-190mm/index.html
Stage 4:
Eventually a Gates belt drive system if possible.
I will research more when the time gets closer, haven’t looked into it that deeply yet except that the BBSHD and XXL have adaptors that will take a belt.
If anyone has any suggestions or wisdom they wish to impart and if there are any questions fire away. I'm evolving as I go.
I’ll update the post as I make progress.
Thanks for reading,
Green
Here is the bike:
Stage 1:
Stage 2:
Stage 3:
Stage 4:
Thanks for reading,
Green
