cor
The BVM is slightly different from the celllog in that it uses a standard LDO to generate 3.3V from a quick glance inside one.amberwolf said:There s a mod for I think the celllogs to make them draw from all cells
Alternately you could mod it to draw power only from external aux battery and tape one to the back.
I also noticed 2 diodes from the 1st and 2nd cell to this regulator.
There is a pair of diodes to power the two quad LM324 opamps but the power draw of those is seriously lower than the processor and backlight.
It will probably still work to add a switch in the negative wire (which internally is connected to the ground of the unit).
One other intriguing thing is 5 mounting holes next to the 3-pin alarm port. I wonder if that is meant for (micro-)USB? After all, the 'S' at the end of the name stands for the serial communication like with the celllog: the -S has USB, the -M has not.
Maybe the software is not implemented enough to support USB?
Anyway, this device does not have the ridiculous powering as the early celllog had, which had a fixed 2k resistor from the highest cell and burned the power away in a 431 set to 3V.
