Glens carzy ebike
- Joined
- Aug 3, 2019
- Messages
- 23
can regen kill your hub motor?
Depends on the strength of the regen, how suddenly / sharply you apply it, how long you apply it, and the temperature conditions at the time, and how much other stuff you do that adds heat to the motor, as well as how well the axle is mounted and secured.Glens carzy ebike said:can regen kill your hub motor?
Or two brake levers, one just inboard of the other, at sligthly different angles, so you use your fingertips to "grab" the ebrake lever or your hand/fingers to grab the regular brake lever. Did that for CrazyBike2 and SB Cruiser, takes a little getting used to, but it works.dogman dan said:On regen trick you should try, connect the regen to a horn button on the bars, so you can get brakes, regen, or brakes and regen at your choice.
