I've been using a CellLog8 for about a year. Today I was setting up a new BMS and for the first time I happened to compare the CellLog with my metered values. to my surprise it was noticably off, both on the overall value and the per-cell.
28.7 on the cell log and 29.41 on meter. Quite a big difference. Has anyone else seen this type of behavior?
I've hooked i up using a DB9 using an old mouse port and ribbon cables... (It makes for a nice watertight connection that is easy to connect through the batter case:
The setup is TP 3S connectors on the balance plugs connecting in parallel to both the BMS and the ribbon cable leading to the DB9, with the mating DB9 on the outside connecting to the Celllog8 leads. All connections are soldered. (The balance plugs are for connecting 2P, though now it only has 1 pack per connection).
Is it possible that the thinner /longer wires (hence higher resistance) are hence impacting the voltage reading? (there was no instruction limits on installin git).
Or is possible that its caused now because have it in parallel with the BMS lines (before it was straight connection balance leads to DB9 to DB9 to celllog, but I never compared it with the meter).
Also I'm wondering if this might be why I killed some of my lipos, since a few times when I knew I'd need greater capacity for a longer ride, I let it charge until the CellLog said 4.2. The per-cell on the above was as high as 4.24 on the meter cells showing 4.11 on the cell log. (I know its high, but I allowed it to go to 4.24 to test the BMS).
