jdcburg
Can someone explain to me what happened here: I have a celllog 8m that I wanted to use as a LVC with 8 Thundersky 20ah cells. I have an inexpensive JC-116 controller that has an ignition plug and a plug for a brake switch. The ignition plug requires a closed switch to operate (I use a bent paper clip) and the brake switch is normally open – it kills the motor if it’s closed. I tried the brake plug with a bent paper clip and it works as it should so I thought either of those 2 places would be a good place to connect the celllog external alarm output for a LVC - NO for the brake switch or NC for the ignition.
I don’t read schematics and I don’t do that well with Chinglish. I have attached what I think are the relevant schematics and explanations of the alarm circuit from the celllog manual. When I read the instructions about the “short circuit,†I thought the alarm circuit would make a switch across the red and black wires, depending on the NO/NC setting and alarm state. First I tried attaching the wires to the brake connector with the alarm output NO position. The motor ran normally. Then I switched it to NC, which I thought would cut the power, but it didn’t. Next I tried the probes of my digital multimeter in the ignition plug. The voltage was 27.02. The DC milliamps on the 200 ma setting read 37.9-38.0 whether the motor is turning under power or not. Those numbers are well below the celllog limits of 50v, 500 mA. So then I decided to try connecting the alarm output wires to the ignition plug while the celllog was still set at NC. I plugged the black wire into one side of the ignition plug. The red wire was not plugged into anything. I happened to pick the + side of the ignition plug. There was a giant spark. I jumped pretty good. I suspect a few more than 38 mA passed through those wires at that instant. BTW, the bent paperclip has never sparked when I insert or remove it. I’m guessing the black side of the alarm circuit is not isolated from the negative battery terminal when the alarm output is set to NC? Both the controller and celllog seem to work fine but the alarm output circuit appears to be fried. I have ordered a new celllog and will probably go with a external buzzer or LED but I wonder (1) why the brake circuit wouldn’t cut the motor when I switched the alarm output to NC and (2) what happened with the ignition plug? Thanks for any advice - jd
