Ok, maybe a dumb question but...if I were to charge a batt pack with a charger that is higher voltage than the pack would the bms manage the higher voltage and limit it or would it wreck the bms and/or batteries?
1) I bought a 12s5p (2ah 3.7v nominal cells at 44.4v nom / 50.4v max charge) lithium ion pack and a compatible 45a bms and a charger
Problem is the charger I received states 48v on a small sticker on the front of the charger that seems like it was slapped on after the fact (but if correct the voltage would already be too high potentially for my pack as it would be a 13s charger with a 12s pack) but the "official" specs sticker on the back of the charger reads "output: 57.6v dc 3a"...
Normally I would assume if I didnt have a bms and was simply charging a battery pack directly that the charger should match as closely as possible to the batt specs but since I have a bms attached I was sure how it affected the scenario if at all...
