Alexanderfoti
- Joined
- Jun 18, 2016
- Messages
- 78
Hi all!!
I need to charge a Li-ion pack that is 26S, to a nominal voltage of 107.9VDC (4.15V per cell).
I have a few chargers I have found on Aliexpress
https://www.aliexpress.com/store/product/Li-Ion-Battery-72v-3A-4A-5A-6A-7A-8A-9A-10A-11A-12A-Adjustable-Current/4450039_32914065128.html?spm=2114.12010612.8148356.18.792d1fa7wPkbW1
This, and and most others, will do CC at 12A until they hit a certain voltage, and then switch to CV mode.
One seller sent me this:
https://www.aliexpress.com/store/product/3000W-Big-Power-0-90v-0-120v-Adjustable-Lithium-Battery-Charger-0-30A-Adjustable-Charger-for/4450039_32964180998.html?spm=2114.12010612.8148356.2.792d1fa7wPkbW1
As far as I can tell, this is just a large power supply with no CC/CV circuit. I can set an upper voltage limit and a current limit, so I assume it will dump current into the pack at the set current (25A for example) until it reaches the output voltage of the charger, but will taper off, and not have an intelligent control.
If anyone can give me any advice, I will be much appreciated.
