Does anyone have any experience with the charging connector (from charger to battery) for the BOSCH battery (400 Wh) from a Hai Bike? I'm asking as I have a customer wanting me to set up a solar charging system for this type of ebike. It's a typical 36V lithium ion battery but the plug has multiple connection points (for memory - as I don't have one in my shop). Most standard Li 36V battery chargers typically just have a pos and neg wire going to them but some systems have interesting mechanisms. If within this connecter there is just a pos and neg wire then it will be straight forward to charge the battery with a 36V panel and 36V regulator or else a 12V panel with a 12V - 36V DC converter but if there is something funny going on then it will be tricky and there may be a need to lose some efficiency and increase the weight by charging a 12V battery and using an inverter before going through the regular charger (a reliable but not so efficient way). If anyone has experience with the charging system of the BOSCH battery then please send me your suggestions as it will save purchasing and potentially sacrificing a charger. Thanks in advance.
Matt, Solar Bike. www.solarbike.com.au
