DanGT86
Makes perfect sense about some of the losses having a linear relationship with torque and speed and some being constant. Thanks.
That got me thinking about chains. My 219 chain feels really dense. It got me thinking about how when in motion around 2 sprockets that is a lot of weight that is being constantly flung in different directions. As it makes its way around a sprocket it is being effectively accelerated the whole time. Around a small sprocket it basically gets thrown one way then instantly makes a turn and comes back the other way. At first glance it seems like tons of wasted energy. The smaller the sprocket the closer to reciprocating mass it becomes...Maybe?
But after further thought I reasoned that because its a loop there is always another part of the chain effectively cancelling out that motion. For example the chain mass reversing direction as it passes the apex of the sprocket is being pulled by the inertia of the chain that already made that 180. And its being effectively pushed by the links that havent made the turn yet..... Then my head exploded.
So long story/question short: does the inertia from the chains mass pretty much cancel out between the load side and the slack side? If you have a bunch of directional changes like many sprockets and idlers do they all cancel just reducing to bearing and frictional drag? Does the physical path of the chain in space require different amounts of power to rotate?
