Hi everyone, I am new here. First of all, sorry for my English. I really need some suggestion... Can't imagine how stupid am I .
I have a Tongsheng tsdz2b kit and 48V-19.2Ah battery.
I accidently connect the battery to the motor in backward (positive to negative) . I heard a little kick sound from the motor when I power on the battery. I tried to press the power button on my 850c display but it kept being off.
The power cable from the battery to the motor was warn when I touched it (huge current flowed through it). I realized I was doing something wrong. I unpluged the power cable out of the motor and found out that it was connected in backward.
I pressed the button power indicator button on the battery to check the battery status. There was only one red led out of 4 leds light up (it were 3 greens and 1 red before the accident)
I tried to connect battery to the motor correctly. There was no hope, the screen kept being black (.
I plugged my 5V lamp to the usb port on the battery, it worked, the lamb turned on. However I found out the power button (switch) on the battery doesn't work anymore as I turn it off but the lamp was still on.
I tried to charge the battery overnight (for 6h). Then I connect it to the motor again but still no hope. The thing is the led indicator on the charger was green when I plug it to the battery, meaning there was no charge current to the battery.
Now I don't know whether my motor or my battery is still alive. I hope there was some protection mechanism to cutoff the circuit during the accident.
You can see in the photo, the system was totally fine the night before the accident.
I post here to look for any suggestion… The thing is I have no experience on the tsdz2 system because I have just bought the motor and battery a few days ago, haven't install it on the bike yet . I appreciate all of your comments. Thanks!
