All,
I converted a mountain bike to E using a standard china 1000W rear hub kit. Specifically I used the Voilamart kit with the SW900 display and it works well.
The main issue is the PAS experience. I was really hoping for "true" PAS similar to other off the shelf E-Bikes. The kit has a the standard ring type PAS sensor and the controller uses it as essentially an on/off switch.
So currently,
1. You start to pedal, the motor goes to full power.
2. PAS level (selectable on the screen) is basically a max speed setting, no impact to power.
so it's basically a cruise control feature that kicks in as soon as you pedal.
I realize that my system lacks a true torque sensor, however i've read little information on "torque simulating sinewave controllers" ? and other things but the literature is sparce with little information on specific controllers and how they behave. BMSbattery controllers? KT controllers?
I would love a recommendation on what I can do or change to get the desired PAS experience i am looking for. I appreciate the help.
So currently,
