well, I am also interested in the 18650 25R or 26650 A123...
just don't know which one to go for, especially if the 7.5AH is enough for my dual diagonal 63mm 150 setup.
SAMSUNG 18650 25R
regarding a pack made of samsung 25R 10S 7,5ah would be 10s3p right which means 30 cells.
one cell is 1,7cm (diameter) x 6,6 cm (length) - 45grams raw specs.
I just measured the available space on my existing deck, I could allocate a space of 30cm (length) x 18cm (width).
so in length/width at the maximum, I could get a pack of 30 cells that will be : 25,5cm (15x1,7) x 13,2 (2x6,6)
weight would be around 30x45grams : 1,350kg
pack cost is around 30x 4,30 euros = 129 euros (+20 shipping + 10 for tabs) => 150 euros maximum.
that's awesome if the calculation is right ! I have some spare in width and length for wiring
for A123 26650M1 B Grade 3,3V - same : 10s3P - 30 cells
one cell is 2,6cm (diameter) x 6,5 cm - 76 grams raw specs
at the maximum I could align on 30cm ... two lines of 11 cells.. which will be 22 cells... I need to find 8 more.. maybe on the side of the pack, 4 each side.
pack cost : 30 x 7,5 = 225 + shipping & tabs : 250 euros maximum
pack weight : 30x76 = 2,280kg.
