jonescg
I recently re-packed an e-bike battery for a friend using 18650 cells, and while the hexagonal Kart kit was a dream to work with, the final terminations had me scratching my head. I ended up spot-welding the last parallel cells with excess tab and soldered heavier gauge wire to it - maybe 2.5 mm2 and adding connectors to that. I should also add I built a little case with FR4 and tape and potted the whole lot in epoxy resin.
But the end termination was pretty inelegant. Does anyone else have a nice solution for robust, high current connections to the first and last cells of an 18650 pack? The trick is to reliably get the power out, share the current evenly, and ensure it's robust enough to survive a thrashing.
And yes, I forgot to take a photo of the whole lot :x
