Hi, I'm planning on running two 2P10S battery packs in parallel. Each pack will have identical cells and its own BMS. Each pack will be charged separately.
I want to connect one of these ammeters (see link below) at the output of each battery pack to monitor the currents, ensuring they are similar. I will mount each display on the handlebars of my bike. The motor controller is set to draw a total of 15A so ideally, each pack will output 7.5A. The ammeters can read up to 10A so I think they are suitable.
https://www.aliexpress.com/item/32310008404.html
The ammeters require a voltage supply of 4-30V so I cannot provide this directly from my battery (cutoff range ~30-41V).
I don't want a separate power supply to power these cheap ammeters. I don't want to tap out of a 3S or 4S group of cells on one pack. Only other option I can think of is to use a DCDC step down converter.
I've had a look on Mouser, Ebay and somewhat reluctantly, AliExpress for DC-DC converters. I don't have any experience using DCDC converters so I'm a bit of a noob when selecting the right one. Here are some examples that I've considered.
https://m.aliexpress.com/item/33054259205.html?sellerAdminSeq=226886743&spm=a2g0n.search-amp.list.33054259205&aff_trace_key=22043cce436742dfa35e12a3d302d5de-1566158119908-04754-UneMJZVf&aff_platform=msite&m_page_id=1256amp-08GfH0xX6GcbuLEnOKnLXA1566159468714
https://www.ebay.co.uk/itm/VI-JN3-CW-36v-76v-In-24v-100W-Out-Isolated-DC-DC-Converter-VICOR/113847624322?hash=item1a81d8e282:g:9rAAAOSw~fFdTFyl
Are either of these any good/suitable? If not, can anyone suggest any better alternatives?
Thanks!
Thanks!
