flyingpants
Hi there. Like the title says, I'm looking to design a bike that can climb any hill. The Bafang BBS series is great, but expensive, and I like my front gears. Also, I'm always scared the chain will not shift properly, or get caught on my shoelace or something. So, no mid-drive!
A hub motor is great for pedal assist, but not for hill climbing. The Xiongda dual-speed internally-geared motor is a great concept but there have been many reports of failures. So I thought how to design my own solution.
Requirements:
My solution is a dual motor setup. A cheap hub motor geared to the back wheel like this: http://i.imgur.com/Xq2h8XC.png It only needs to go 8-9km uphill, nothing more. For the rest of the time, you'll be going downhill, or cruising, and can rely on another ~3.5lbs motor on the front wheel, maybe with pedal assist.
Is it worth it to bolt the motor on like that for the extra torque?
Requirements:
It needs to do a 8-9km/h up most hills with no pedalling
Hill climbing should be fairly efficient, unlike most hub motors
It needs to do 20km/h+ on flat roads, 25+ with pedal assist
Total system weight should be under 7-8lbs (minus battery)
Total system cost should be ~$200 ish (minus battery)
It will use a small 3lbs 300W battery or similar
