John Bozi
Went for my ride and the chain only skipped once.drew12345 said:Cool John! Sounds like your getting the chain skipping figured out. So how is it handle the hills? How is speed?
That sounds great because the last ride I couldn't get up moderate inclines (in my books.
So I took the kit for the first time to true steep sections.
I am struggling to find how to climb them with this kit. If I leave the power open to 5kw I find climbing super steep complex rough terrain uncontrollable.
So I kept trialling setting on the CA to limit power but nothing seemed doable.
The trottle is too twitchy. When you are on an incline maybe 20+, stuff where you are holding the brake lever and trying to not slide backward and then try to bring on the power, I found I couldn't manage the power level.
Take up a step back. I can do all this terrain with my tiny slow bafang motor geared to super slow. It has the perfect amount of torque in its one gear to climb everything that traction will allow. It does it at wot
so there is no thought at your hand trying to manage the power. At 10kmh there is the perfect speed to climb the point before traction loss and the terrain is always rocks here and there which must be manouvered through
so that you don't come to a stand still.
Yes the bafang would overheat if doing this continuously for over 5 minutes but it got me through to the parts where the hub could kick in again.
With the LR you have to bring on the possible 5kw slowly so you don't flip or go into a spin on what is already a hard to hop on bicycle angle.
I had a skip on the chain and gave up after a few attempts to do what my bafang could manage. I will probably have to go to a larger rear sprocket some how to get even more tooth engagement. That will then mean an even higher pitched scream to get to the same speeds. I don't see the need for a smaller chainring at the BB now...
So the CA is kind of useless in trying to manage power in the tight band of power because it cuts in and out the power limiting to abruptly.
I tried to limit power so I couldn't flip the bike because it was already on an angle but when you are depending on its management with your balance leaning over the handle bars you can't have power cuts and then the power cutting in
because you just can't keep your momentum. After trying many settings I felt no setting on the CA were the best as usual. That's why I rode for so long with the blue
throttle wire pulled out of the ca plug. The fluid movement of the hand is better than the jigging in out of the ca a million times.
Hence I come back to my same point of running one motor in one gearing.
I am sad to say for now that riding the steepest 10% of terrain that I could with my dual motor looks to be an almost impossibility with the LR kit. The big block kit is better at the moderate steep, but not the extreme steep.
Lets talk about heat. The motor is not a point worth mentioning because the controller is far hotter all the time.
Lets talk about sound. The primary chain is ridiculously loud. It makes me extremely worried where I ride about upsetting people.
Let's talk about the the steel and chains. On the kit the chains loosened up on the ride and became slack and more noisy. There is no doubt that only a couple of AHs into a ride that I need to carry tools to retighten this when pushing over 2kw. So really there is no point to the big block with the drivetrain system I have now.
If I can't harness more than 2.5kw then the small block is lighter and just as capable.
I am still glad I got the big block because if in the future I get time to custom up the drive train things might get better. For now the big block can take much more power than I can actually get the rest of the bike to use.
