You probably won't get much in teh way of braking on it unless you have significant weight on there--the wheel may just lose traction.
Same is true of drive power--if you have a lot of torque without enough weight holding it to the road, the wheel may spin if you suddenly apply it at a low enough speed.
A good DD motor, well-made, doens't have much resistance when unpowered (though there is still some, and you'll probably feel it).
A good freewheeling geared motor, well-made, does still have some resistance when unpowered, though not very much, and is significantly easier to pedal than a badly-made/designed DD motor, and still noticeably easier than a well-made one.
I can feel a definite difference between the typical "9C" type DD motor, and either the older or newer Fusin geared hubs I have. THe older Fusin and a 9C were each used on DayGlo Avenger, with the 9C being harder to pedal the faster I went, though not that much difference at low speeds. The newer FUsin was about teh same as the older, though used on a different bike (and later a trike).
I did not test this, but I expect that with the controller's phase wires disconnected from the motor, (or the battery from the controller) it would be easier to pedal at higher speeds.
Speculation: Depending on which setup, the geared motor, for the same wheel and motor size, controller, and battery, may have higher torque than the DD, so you might have to apply it more slowly than the DD to prevent wheelspin.
Either way, it depends mostly on what you want out of it.
