Astropower
Hello,
I have Battery Pack that i build with 16 cells of 15Ah, LiFePO4 (3.2V Nominal 3.65V Maximum).
I dont want to use in BMS, my opinion that i waste of money.
the most two important things to protect the cells, to cut off the battery when voltage too low, my Motor controller have this function.
Second, is to balance the cells while charging.
I found this Balance module :
http://www.batteryspace.com/Balance-Module-for-3.2V-LiFePO4-Battery-Pack.aspx
but it very expensive.
So i was thing to build Balance module to my 16 cells with 32 pcs of Zener diode number: 1N5334B
http://www.onsemi.com/pub_link/Collateral/1N5333B-D.PDF
Nominal Zener voltage 3.6V and 1320mA Balance (with two diode on parallel on each cell 2.64A Balance).
i think it good and cheap solution, to balance while charging.
I would like to get your opinions...
