The outer diameter of pulley is 46mm, it's 48 teeth HTD 3M 15.bbcane78 said:I'm planning on doing a similar design, I have a quick question though. I'm using 83mm flywheels and I'm wondering what size belt pulley you used, I know the bore was 8mm but what is the diameter for the pulley as a whole?
bbcane78 said:Would this setup work? Any recommendations if not or what could make it better?
2X http://www.hobbyking.com/hobbyking/store/__22036__NTM_Prop_Drive_50_60_270KV_2400W.html
http://hobbyking.com/hobbyking/store/__28224__HobbyKing_120A_Boat_ESC_4A_UBEC.html
2X http://www.hobbyking.com/hobbyking/store/__8579__ZIPPY_Flightmax_5000mAh_3S1P_20C.html
http://www.hobbyking.com/hobbyking/store/__5548__IMAX_B6_50W_5A_Charger_Discharger_1_6_Cells_GENUINE_.html
Also not so hot about the batteries, if anyone knows of any that are better, would have a longer life and more power in the same price range that would be awesome!
sl33py said:bbcane78 said:Would this setup work? Any recommendations if not or what could make it better?
I would recommend you start a build/help thread so folks can guide you through this.
most everything looks ok except your ESC. You want a car ESC not boat or heli. The brakes (kind of important) don't work quite right on boat and heli ESC's. Dual 5060's should work great, but you will have trouble fitting the 5060's dual rear without spacers and wider trucks (i used Paris 195's on my dual 5060 (Torque's 5060 or 5065 - not positive any longer) setup. It was tight and spacers were needed (about 5mm ea side). Dual diagonal will work obviously.
Start a thread and we'll get you squared away!
GL!
makithepaki said:Hey i have some questions for you or if someone else could answer them.
1. where did you get that screen with the battery indicateur.
2. where did you buy poweron button
3. how did you setup on board charging
okp said:Hey Squad,
My wattmeter failed last week. I had the same battery % mesure component in my tool case, so decided to install it like you did
Do you think this device worth? Not tried it yet as yesterday night was the Parisian massacre 200m from my appartement. Crazy, especially because two days ago I was at the Bataclan for a night show/party.
Nice ride!
makithepaki said:Hey sqaud so for the discharge connector was it connected like this
http://cdn.instructables.com/F80/D3M0/IDLI6KE5/F80D3M0IDLI6KE5.LARGE.jpg
randyc1 said:Beautifull build Squad !!
Newbie Questions:
I am amazed at how much speed you get on 7(S)!, have'nt seen many builds with these motors (very affordable aslo)
With these motors and your setup ,do have have plenty of torque ?
How does it accelerate from a complete standstill ?
Thanks !
randyc1 said:Thanks Squad, btw, i was able to see only 1 pic ?,..the one with all your parts gathered on the floor for the build , where there many pics?
