Zynode
- Joined
- Mar 13, 2021
- Messages
- 4
EDIT 22.02.2022. The seller has agreed to repair the pack. Obviously no warranty due to mechanical damages.
EDIT 07.04.2022. The seller has repaired the pack and said that the nickel plating connection came loose for a cell group that made the pack go out of balance as well as bad BMS.
Hi. I have 48V17.25Ah battery pack 13S5P with Samsung SDI INR18650-35E cells from enerprof.de.
Specs: BMS Continuous Discharge Current: 22A. The problem is that i believe i have a dead cell. I charged the pack to full and then left for few hours to balance but it was only 52.2V instead of 54.6V. Okay i balanced it to 54.6V and now a week or so later it's again about 52.2V. I believe i've had this issue for a long time (probably since i crashed a few times at the start (oops)). And that would explain the various cutoffs i've had at max amps (22).
I don't think i'm pushing the pack as i'm running it around 22A. I have 4V sag at full load (~40km/h), ~2.4V at ~35km/hAccording to cell sheet it's 8A discharge, 5P is 40A so i'm running it conservatively? Cell spec sheet - https://lygte-info.dk/review/batteries2012/Samsung%20INR18650-35E%203500mAh%20(Pink)%20UK.html
So the question is - do i have a dead cell? But if so then how could i balance it back up to 54.6V after ~24 hours? And how does it empty so fast? Do i have to rebalance it multiplte times? Any help is appreciated. Already asked the seller for what to do.
