Yes you are right!.. But from now i need the crate to comeback from interbike, rebuild the bike in one piece and finish building the 100kW lipo drag racing pack!
btw this pack will be awsome! 13 miliohms ( abmiant temp of 25C) total resistance!
let's have fun with math!
The optimum voltage to get lowest internal resistance is 3.9V per cell
and 3.9 x 22s = 85.8V witch is exactly what Jeka, the Adaptto engineer recommand as the optimum voltage for max ouput :wink:
Now the peak amp that can be sraw from this pack before reaching the 3.0V is calculated as :
Max allowable voltage drop :85.8V-(22x3.0V) = 19.2V
Max I = (Vdrop / Ir) = 1476A !!!.. That's 97.4kW !!!
These pack are rated 150C.. and these are 9Ah total.. That's pretty close with (9Ah*150C)=1350A
The amp limit will be the controller and the 8 gauge wire!.. But the fusing point of 8 Awg copper wire of these pack is 475A and i have two parallel ... so.... let say the max amp is: 950A.. That's stil alot !!! 950A * 0.013 = 12.35Vdrop = 73.5V pack volt at 950A... That's 69.8kW... right before seeing these silicon wire red hot !!!
That is still more than twice the current that both of my controllel rwill draw ( 375A and 32kW)!
This awsome pack will be 6" x 4" x 6".
I will build a strong aluminum box to keep cells compressed and help keeping low internal resistance.
Both end will be 3/16" T6 allu and sides and bottom will be 3/32".
Doc
