John Tetz's low power assist seems like a perfect way for me to shorten my 10 mile commute by giving me a kick to cruise at 20MPH instead of 15. I've run across so many posts about detonating gearboxes (such as the Bane Bots P60s I was looking at) that while Tetz came up with a current limiter to avoid that, I'm still worried.
Looking at designs that use hubmotors to drive through a chain, I was intrigued, but want something smaller & lighter.
What about using a motor at 1/10th of it's rated output at a low speed? Something like a 3kW Turnigy with a <20 tooth freewheel driving the main drive chain. I ride a recumbent, so I'd like to mount the motor so the existing idler works to increase wrap around the motor drive cog.
It looks like the RPMs would just be too too low, though. A 52 tooth chainwheel at 90 RPM pedaling would only have an 18 tooth motor cog going at 260RPM or 1.5V at, what 80 Amps? That's only 120 Watts and needs some fat supply wires. Is the motor so inefficient at this low speed that it's effectively a heater that happens to rotate?
Is there any point in this line of thought? Using a single instead of dual stage reduction with easy to get pulleys for only 8:1?
