I had a feeling they were GM's. I noticed the GM battery was exactly tyhe same, but even with shipping, GM's battey was cheaper. I ordered the older GM battery, which was $353 with shipping. The one that slides on would have been $395. But they had neither in stock, and ended up sending me the newer 36v 12ah battery, which is one that also slides on, like the ones in the previous pics. The motor I got from ebike.com has exactly the same dimensions as the GM, and now I'm reading theat they did indeed get their motors from GM at one time. I finally finished my tadpole and installed the motor. First thing I noticed, was some of the spokes felt very loose. I installed the wheel. Lo and behold, it was so out of true, it seemed like nobody bothered to true it up. After a half hour, I had it perfectly trued up. I hooked everything up, and tested it. It worked fine, but seemed slower than some 400w hub motors I've seen. But it performed quite nicely when I took it for a spin. I only have drum brakes on the front wheel, and no rear brake. I was concerned that at higher speeds, I may need the third brake. I didn't stop quite as quickly as I'd like.
Rather than weld a caliper tab on the frame, I tried the GM ontroller that I had. It has regen braking, which I like for the braking rather than the battery recharge, and reverse, which is a nice plus with a trike. The motor ran even better. It's a bit faster, I guess due to the higher amp controller. And at high speeds, the regen braking really helps. The trike stopped on a dime at full speed.
The wheel being out of true really ticked me off, and now that it seems this is a GM motor, I feel like I've been had. I specifically went to a higher priced kit, thinking the quality was better than the cheapos, like WE's. And this motor looks identical to the GM motor, except for the paint.
