I'm in the middle of installing an E-Rider BB torque sensor, and when I fully tighten the chainring spider to the thing that it bolts to, there is about 4mm of screw protruding on the inside. It rubs up against the drive-side BB bearing/shell long before the bolt can be fully tightened.
The spider looks a bit different than the pictures on ebikes.ca (where I bought it), so I'm wondering if they might have updated the spider without updating the bolts (10mm). I'm fine getting shorter bolts or using some washers or whatever to space things out, but I want to make sure I haven't screwed something up along the way (maybe there's a little spacer ring or something I lost?).
It's the 5-leg 68mm unit, and I double and triple checked that my BB shell (and the old BB) is 68mm.
