1000w
Excellent donor bikes Aussie. And I like the price.
Cheers,
Matt.
Cheers,
Matt.
1000w said:Excellent donor bikes Aussie. And I like the price.
Cheers,
Matt.
Ben said:Wow, it's a lot bigger than I imagined.
If that's a 26" it's going to look figgin' huge with a 20" on it.
1000w said:Looking good! I love the shape you are creating.
Cheers,
Matt.
1000w said:Good work Kim. The frame has some great looking bends and curves.
Cheers,
Matt.
Miles said:Hi Aussie,
The structure looks fine, a space-frame with round tubing would look more elegant, though. I'm more concerned about the pivot placement for the swing arm. The suspension will be most effective if the wheel moves upwards and backwards. If the axle is above the pivot it will move upwards and forwards. Is it too late to raise the pivot point?
Miles said:I realise there's a lot to juggle with as the gear hub has to go there as well. I'm not sure how much difference it would make, in practice...... maybe someone else will chime in. Anyway, certainly something to bear in mind for Mk 2 :wink:
TylerDurden said:Hi Jester,
My first impression upon seeing the pix, was the mitre in the swingarm enduring constant tension and impact loads.
If adequate is simply dealing with cracks in the footpath, I would say it's fine.AussieJester said:The question is whether the pivot point being lower than the axle will impact greatly on the suspension working adequately, do you have any idea about this at all ?
TylerDurden said:If adequate is simply dealing with cracks in the footpath, I would say it's fine.
Sorry, KimAussieJester said:now miles has bought this issue to my attention I can't seem to settle on what to do...
