ralphius
- Joined
- Mar 3, 2019
- Messages
- 15
Hi,
I have an old Crystalyte 408 hub motor kit on my self-built ebike. After lots of commuting, the original battery (from 2014!) finally died in Jan 2020 and I bought a replacement "Hailong Battery 48V 13Ah 13S 5P Li-ion with charger" soon afterwards. The ebike got virtually no use through 2020 due to Covid and lockdowns, and ever since then I've been working from home so I only really use it to get myself up the hill to the pub! Not sure how many miles I do now but I find myself charging it once every 3 weeks so the new battery has had very few charge-discharge cycles.
I do carefully track the amount of energy it takes to recharge the battery with a power monitoring plug and I've noticed something odd recently. The charger doesn't seem to be switching off properly anymore?
This was the power and energy (595Wh taken) taken by the charger that came with the new battery when the battery was nearly new:
(It switched itself off with an audible click at 9:45PM)
And this is how the same charger behaves recently (580Wh taken):
I would have expected the charger to turn off at 20:00, but it didn't. Instead it continued to "trickle charge" until 21:35 when I manually switched it off. Is this normal or a problem?
Thanks in advance for any insights you may have,
Ralphius
Ralphius
