The brushless hubs that are common around here will put out some voltage when they are spun. Regen is proof of that. However, these hubs were not designed to perform their best as a generator. This ine of thinking has been pondered before. The wind changess direction, and also there is much more wind about 60-feet above ground level, as long as there are not any trees nearby. Wind-generator towers are cumbersome and somewhat expensive in relation to the amount of power you can get by having some sort of turbine spinning a roller that drives the tire to recharge your batteries while you are at work.
I would guess that your best bang for your buck to recharge your bike off the grid would be to have a decent-sized solar-panel charging a deep-cycle battery bank, and use the battery bank to charge your bike.
If you are asking if you can use your E-bike battery pack as a back-up power source, the answer is yes. If you want to use off-the-shelf inverters to make 120VAC, I believe a 48V pack would be the easiest to set up. There are 24V off-grid inverters (for sailboats), but I haven't heard of 36V or 72V components for this.
I have chosen a 12V interface for my back-up power. I have a 45W solar-panel that is in 3 sections so it can be folded to fit through a door, allowing it to be stored indoors in the evening. with 12V I can charge AA batteries (Sanyo eneloops) for pocket flashlights and a couple lanterns. The panel charges a large 12V deep-cycle battery, that I can also use to charge my cell-phone and laptop.
I would love a more comprehensive system if I could afford it, but this is what I have right now. I think it would be very inefficient to run a TV with a 48V E-bike pack driving a 120VAC inverter. I would be more likely to use 12V to watch Hulu/Netflix and the news on the web through my laptop.
http://otherpower.com/, and their chat forum,
http://www.fieldlines.com/index has a lot of off-grid info. Also
http://www.thebackshed.com, and
http://www.builditsolar.com
An ebike controller is not set-up for the type of duty you describe. spinning the rear tire will create regen, and I honestly don't know if it would work well or fry a part that was not designed for continuous regen heat over hours of charging. It might be an interesting experiment.
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Cromotor, it is heavy/wide so that it can take a LOT of amps. A lot of people are happy using 25A on a 9C and a 6-FET controller, and 35A on a Crystalyte HT and a 12-FET. The Cromotor on an 18-FET can run relatively cool at...I'm guessing 45A? with occasional temporary bursts of 60A (I've never owned or ridden one). You will need LiPo for the C-rate, and even then a 72V / 45A continuous-capable battery pack will be large and expensive.
Best of luck with whatever you decide.
