Navarro said:
I will try to do this, hopefully I will not destroy anything...
Did some more troubleshooting, all seems ok, except for the shuddered start once in 4-5 starts. Also, the power indicator in the display is always quite low (I am always expecting 300-400w on the power meter but it does not jump more than 20-30w - really really low even if the wheel spins very fast).
Will keep you posted.
LATER EDIT:
1.With the wheel on the groud - no torque, the controller just shuts off and I get "03 info" error.
2.Ok...Check Halls sensors again - the result is in the video below.
https://youtu.be/qcUj9YmWGas
3.Controller is new. Pic is below.
4.With the wheel up, shuddered start once in 4-5 starts, power meter shows 0w even when spedometer shows 10-14 kmph.
5.Checked throttle... Video below.
https://youtu.be/114aDO4f-rw
6.Checked controller phase... Video below.
https://youtu.be/p-VTDAYktW4
Mindblown right now. How can the second controller see Hall issues (like the first one - which the tester showed it as faulty) when the tester shows ok? And why do I get the strange behaviour with the wheel up?
Starting to believe a Hall-less controller is the way to go.
The old controller may be fine, it functioned for 800 km with the hall sensor wiring order in the connector. The new controller may have different wiring colours, and it seems to be throwing the same code.
Get yourself a stand to lift the back wheel off the ground.
Check the battery voltage at the battery connector to see if it drops when applying throttle. If the battery is not an issue then....
Sounds like a bad connection or short in the hall wiring.
Or phase wiring order, the new controller may have different colours for different phases. (My phase colours never line up)
Look inside the phase wire connector make sure all pins are ok and do not push out when connecting the two ends.
For the hall sensor short:
A simple test would be to unplug the hall sensor connector, take a volt meter and set to ohms and attach one of the volt meter leads to the motor shaft, and test each individual hall sensor at the connector.
As you are testing move the hall sensor wires around and see if there are any shorts.
Check ohms between all phase wires too.
Phase wires:
Try all variation
There is a chart around which has all combinations for hall and phase, which you can check off one by one, quite a few combinations.
