Ebike Tigershark battery connector help
Mickp10
Seeking help identifying battery connector type the Tigershark battery case use on the Kristall/Twitter/Avocado batteries in photos below.
I am wanting to use a XT60 to a Tigershark battery connector to mount the 48v ebike battery as external battery for my Zero 9/Titan Unicool T9 electric scooter.
Thanks for your help
That will take a bit of work to swap the connector and have it smoothly engage a connection with the battery on the mount engaging the connector on the mount. Thats not what XT's are known for, even the slightest fuckup moves the encased the bullet of the xt. XT's are not meant that type of connection, its more of a feel type deal, where you physically manipulate the connector to slide into each other by slightly moving one side, if its off by a hair the method you already have is not doable.
First thing that comes to mind with that connector is XLR, but I have my doubts its actually that.
Try this:
https://www.greenbikekit.com/e-bike-tigershark-frame-battery-plug-2p-6pins.html
