calfeetwenty
- Joined
- Aug 12, 2016
- Messages
- 67
There is just a "T". The only time one would use a proportioning valve is when linking front to rear.
the 273 is bigger in size that's why they are calles a 273 your standard hub motors are 205 mmGstegman said:I am the new guy but thought the 273 was 8000w and physically much bigger? Still cheap!
https://www.google.com/search?q=qs+273+v3+8000w+motor&prmd=sivn&source=lnms&tbm=isch&sa=X&ved=0ahUKEwiegJKJq6DdAhVHSq0KHRSJBjYQ_AUIEigC&biw=414&bih=613&dpr=3#imgrc=rZzIiOPnQfrGCM:
Hey Newbie here, if you dont mind me asking; how much was your battery from west coast?Green Werks said:FYI
If you make your own battery mounts
A 20s 10p 72v 18650 battery will fit
This battery has a100amp BMS with 200 Samsung 30Q cells
It can be had from West Coast Electric Cycles (Barent) member here
Great dude straight up and on top of his game
Is that from em3ev? Any pics on how you mounted in frame? Eeb makes a battery box for our frames. Wondering if this setup fits.harmonist said:New battery arrived this morning, can't wait to get that bad boy plugged in!
Thanks brotha for the photos. Nice rig btw. Is that a 72v, 29.5ah? Hows the volt sag? Man I wish em3ev would put a 100a continuous/150 peak bms in the 72v batteries.harmonist said:That battery box looks like it would fit fine, the em3ev battery is 140mm wide and presses firmly against the side panels but they will give slightly for that box to fit, I might have a look at getting one as well.
I've just got the battery sitting in there with padding around it at the moment and it does the job, doesn't move around or anything but I'm just riding on the road at the moment, kinda like this but with more padding now.
I've got the controller mounted on the outside for better cooling so the bike looks like this now.
Thanks for the info brotha.harmonist said:Yip thats the one with 30Q cells, think it sags around 2-3v when gunning it at 95a so not too bad at all, I've never had the battery warm up on me yet, its always the motor and controller that are scorching before the battery gets a chance to get warm.
Does your tft display correct motor temps? Seems the silver wire on halls is the temp wire, so I'm guessing just by connecting the hall to controller should display motor temps?Gstegman said:I am...
Thanks for the info greatly appreciated.Gstegman said:No, The wire is missing on the controller side so no temp. There are other functions missing as well. If you look at my build thread I posted a pic of the missing wire when I learned this (and started complaining)
Sorry I have not been around here a lot latelyChrisJTX said:Hey Newbie here, if you dont mind me asking; how much was your battery from west coast?Green Werks said:FYI
Sent from my SM-N950U using Tapatalk
